regular exp
Hello all,
Thanks all for serie of suggestions
I went to regexp cause "nn.nn" could be "open" if probe is not connected so it was a manner to
manage this exception. here three possible messages :
\s\s26.41\s\s\s\sopen\00\s\n
\s\sopen\s\s\s\s25.42\00\s\n
\s\sopen\s\s\s\sopen\00\s\n
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 11 of 19
(1,782 Views)
big erratum right ones are
\s\s26.41\s\s\s\s25.42\s\n
\s\sopen\00\s\s\s\s25.42\s\n
\s\sopen\00\s\s\s\sopen\00\s\n
Message 12 of 19
(1,779 Views)
That's quite different from the original post 😉
Here's a quick example of code to extract those string values.  Since I have no clue what you will be doing next, I placed them into a 2-D array.  Depending on what you do next, there may be better ways of implementing the code.
It still uses Scan from String.  I'm sure an elegant solution can also be done using regular expressions.
Message 13 of 19
(1,767 Views)
I think my head is about to explode.
Of course, this always seems to happen whenever I look at regex.
Message 14 of 19
(1,760 Views)
regex are our friends 😉
Message 15 of 19
(1,755 Views)
After looking at these possible messages I think you should definitely go with the Scan from string function. LabVIEW do not support NULL character \00 in regex matching, you will get error -4702 (so sad, regex are so cool).
Ben64
Message 16 of 19
(1,745 Views)
Ben64
Don't let that stop you.
Jim
Message 17 of 19
(1,741 Views)
Obviously you can filter out the NULL character but you then have to use 2 functions to achieve the same result as the Scan from string function.
Ben64
Message 18 of 19
(1,735 Views)
yes and no,
i mention "open" but  i forgot \00 Smiley Sad
the buffers given were 4 differents buffers depending if all (2) sensors are presents or not
Thank you for all detailed examples
Regards
Tinnitus
Message 19 of 19
(1,707 Views)
