regular expresion to match html tags
Hi, everyone, the following is about component code that I'd would like to store in a .xls file. I'm using LabVIEW 2009
I would like to match these words in bold, but I don't know how to handle the attributes ! And I don't find the suitable Regex
<(?<b>.*).*></\k<b>>
The regex should match upper and lower case,
thanks in advance
 eg :
<td width="124"><p align="center"><b><font color="blue" size="3">PS1</font></b></p></td>
<TD WIDTH="125"><P ALIGN="CENTER"><B><FONT COLOR="BLUE" SIZE="3">PS3</FONT></B></P></TD>
<td width="125"><p align="center"><b><font color="blue" size="3">MFC11</font></b></p></td>
Message 1 of 11
(5,863 Views)
Accepted by topic author bauer65
This is the best I could do.
18615iB6644572EE455184
Jim
Message 2 of 11
(5,850 Views)
I found a solution, I'm sharing it with you 😄
Message 3 of 11
(5,831 Views)
I don't know about you, but I like Jim's solution better.... Smiley Wink
Tip: CSS is the preferred method for sylizing text, rather than using tags like <b>. A preferred alternative is to use the <strong> tag.
Message 4 of 11
(5,806 Views)
I like my second solution even better, although I haven't thoroughly tested it.  I don't think it'll work for an arbitrary number of tags.
18669i04490E3882978BCB
Jim
Message 5 of 11
(5,782 Views)
I thought you were kidding...  What a solution.  Smiley Surprised
(Or, "What?  A solution?")
Jim
Message 6 of 11
(5,768 Views)
What's wrong with you ? why are you so mean ?
I made my Vi and it works on my station : you give an URL address and it operates on the source code to find what are between
"<tag>what I want to get back</tag>
Message 7 of 11
(5,735 Views)
I didn't intend to be mean.  I apologize.  You used a :D, which made me think you were laughing at your own solution (so I thought you were kidding) and your original post said nothing about getting information from a URL.
Please forgive me or, at least, ignore my impolite post.
Jim
Message 8 of 11
(5,723 Views)
That's not a fair response. Based on your original post you indicated that you were looking for the bolded text. Jim's solution was very clean, and it's irrelevant whether you're getting the string from a URL or from a string constant. In your solution I see no searching for bold text, and your line "<tag>what I want to get back</tag>" implies that you're actually trying to perform something completely different than what you initially asked for. So perhaps it would be best if in the future the problem is stated a bit more clearly to prevent any confusion or misinterpration.
Message 9 of 11
(5,701 Views)
I don't think I'm mean; I'm average.
Jim
Message 10 of 11
(5,689 Views)
