regular expression for Scan from String
I am trying to pick out three numbers with pattern $number1:number2:number3# from a stream, for instance 8.559509#$-1.686432:-2.427051:-7.281153#$-6.160924:-1.763356:
So far, I use "Scan from String" with Format string "$%f:%f:%f #". However I don't know how to ignore/delete the items before $. Would you like to help me with that? Cheers
(5,048 Views)
You know that your sequence of numbers begins with the $ and ends with the #, so you can separate them into groups first, then separate each number out.
Bill
CLD
(Mid-Level minion.)
(5,032 Views)
Which function should I use to separate these according to $ and #
(5,022 Views)
I have solved the problem. Thank you the hint!
(5,011 Views)
Hi jin,
SpreadsheetStringToArray should help:
(5,008 Views)
A submatch from a Match Regular Expression node can get you there:
Jim
(4,982 Views)
