regular expression help
Well its been a time since I used Expect, so need help with regular
expressions. I need to get the bootloader version from following, what do I
use for the regular expression.
RF Board Version : 255
Bootloader = boot1.1.0.1.abf
SW Bank Information
Current is bank 0
Bank 0 description: CMBUILD_1.1.02.02_RU_V1.5
Bank 1 description: CMBUILD_1.1.02.02_RU_V1.5
(3,091 Views)
I would use a two step process.
First use Match Pattern to look for the string:
Bootloader\s=\s
Make sure that you have enabled slash codes in the regular expression string constant so you can see the spaces.
Next do a search on the string after the match for the expression:
[\r\n]+
This will match any number of carriage returns or line feeds. The string before the match should be what you are looking for.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,091 Views)
Thanks Mike, that's what I had done, using the match pattern VI twice.
vishi
"mikeporter" wrote in message
news:506500000005000000ABE90000-1042324653000@exchange.ni.com...
> Bootloader\s=\s
> [\r\n]+
> Mike...
(3,091 Views)
