regular expression to exclude spaces in string
Now that I'm cross-eyed, I need help with a regular expression.
These need to pass (or permutations thereof):
[00123]
[R012]
[r083]
These need to fail (or permutations thereof):
[test]
[I was here]
[098 876]
[29873 eifvuh]ouh]
I have most of it ( the '[' has to be first; the ']' has to be last; there have to be numbers in the middle, but I can't write an expression that fails if there is 1 or more spaces in the string.
Thanks!
Tay
(12,445 Views)
DO you need it to fail only on sapces? If so then the first one in the fial group would pass [test]
Tim
GHSP
(12,440 Views)
It needs to fail if there are 1 or more spaces, and if there are no numbers, and actually if there is more than one letter, so [test] needs to fail.
Tay
Message Edited by slipstick on 11-20-2009 11:54 AM
(12,436 Views)
Accepted by topic author slipstick
Several possibilities:  Try this regular expression.
^\[[a-zA-Z]*[0-9]+[a-zA-Z0-9]*\]$
(12,418 Views)
Here is what I would do.
Tim
GHSP
(12,415 Views)
Darin.K's version is easier
Tim
GHSP
(12,409 Views)
The filter string is an approach I hadn't thought of. I'll keep it in mind for the future. Both great solutions! Thanks! Tay
(12,398 Views)
