reinitialise while running
Hi all!
I'm running a small vi between a cfp-2020 unit and a tpc-2006 touchscreen, and all is looking good, apart from one niggly little bug! 😞
I connect the two up, no problems, (touchscreen on first, or else the 2020 unit won't have anything to find and stops searching) and get a nice little tick in the connections window on the 2006, showing all is connected and good.  After about 10 mins usually, the tick disappears, and connection cannot be remade unless the 2020 unit is turned off / on or the reset button is pressed.
Is there a way to stop this, or at least make the 2020 unit keep searching for the 2006 if disconnected?
I included the two vi's here, the one named  PDA TCP DS BIODIESEL E1Cb3E2colour2  is obviously for the 2006 unit, and the other for the 2020.
Hope you can help!
Thanks all,
Steven
(2,793 Views)
Double post, please ignore this one.
(2,784 Views)
