reinitialize a signal
I'm adquiring a signal, and plotting this signal. I want that when I stop running my file (using a button) and I run it again,  the signal plot reinitializes.  How can I do this?
Luz
(2,575 Views)
Hi Luz22
  You have two options: use a property node to input a zero-value vector or use a method "reinit to default". There is a great example posted here
http://forums.ni.com/ni/board/message?board.id=170&message.id=86482&requireLogin=False
Hope it helps
Javier Gutiérrez
NI Application Engineering
(2,560 Views)
