reinitialize my program with bottom!
Hi Fonsi...
Sorry, I send you by mistake the wrong VI.
Here is the Good one.
Sorry....
Message 11 of 15
(887 Views)
Hi Bush-man,
Thanks, i am idiot ;).thanks
About the rank answer, sorry!! i didnt understand you.
You help me a lot!.
Regards, Fonsi.
Message 12 of 15
(776 Views)
Hi Altenbach!,
Thank you very much!, i liked your explications, i always want to learn more, i dominate Labview very normal....
The events, its great!, i never used that!.
Regards, Fonsi!.
Message 13 of 15
(776 Views)
Hi atenbach,
I have a final problem, very stupid but i didnt get to remove the precision digites in the first column, rpm.
How can i put 0 digits to precision only in the first column?.
Regards, Fonsi
Message 14 of 15
(776 Views)
Well, you can always build the table the old fashioned way, without all these fancy express tools.
Simply feeed it a 2D array of strings, generated from the data using the desired formatting operations. See attached.
Message 15 of 15
(776 Views)
