related to ms-access
hi,
i have to enter 2 values that is 140/ and some value. i am able to insert and update 140/ and the value to the database.
The problem is with retrieving?
so when i am doing retrieving, both 140/ and the value which is in database is getting retrieved.
i need only the value, but not 140/
how can I do this in labview?
Thanks in Advance
Regards
Soundarya
(2,549 Views)
Hi Soundarya,
why do you always start a new thread? It's the same as here.
You can use a "SELECT" query to get the value you want.
SELECT "yourvaluescolumnname" FROM "yourtablename" WHERE ?='140'
Mike
(2,547 Views)
