relaunch in application
I just studied network stream and found some errors in my code if there is no host program in the condition of timeout is -1.
So, I want my application to have a chance to fix the finite realtime.
However, I would like to know how relaunch current (built not vi) application in current application (just re-starting the application)?
In quitting the application, I close the FP.
(Logically, is it possible to relaunch itself?)
It is very tough time to think aobut other's convenience which I have never considered.
But, this is very nice experience to make the perfect program.
(3,209 Views)
If your network stream is in its own loop, you can just look to see if there's a connection.  If you get the timeout error, close out the connection and try again in the next loop.
(3,178 Views)
