relay switch with wsn
hello
i want to control the air condioni AC with a relay circuit to switch it on and off by WSN (wireless sensor network), i want to send a digital output to the node and then from the node to digital to analog conversion circuit then te analog output to the switch circuit which will be a relay based, so is this possible to do or not ?
(2,781 Views)
Hi duaa,
Could you please be a little more specific about what you want the WSN node to do?  From what you wrote it seems like you want to do digital input and digital output from the node, which is possible.  Is understanding correct?
Matt
(2,759 Views)
I want to take digital input from the node to ac switching circuit to control the ac remotly by wireless so i can make it on and off
(2,756 Views)
If you want to use digital output wirelessly I would reccomend using WLS instead of WSN nodes.  WSN nodes are more for sampling data, than for controlling things.
Here is a link to WLS-9163: http://sine.ni.com/nips/cds/view/p/lang/en/nid/205688
Matt
(2,751 Views)
Thank you for your helpful advice 🙂
(2,746 Views)
