release semaphore with error
I use the example Windows system semaphorehttp://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=BE31D08CF3AF182EE034080020E74861&p_...
I connect errorOut control to the release semaphore, after acquire the semaphore , I release the semaphore an error occurs. How do I fix the issue?
(2,870 Views)
System Semaphore Release uses Call Library Function Node to call ReleaseSemaphore in the Windows kernel. The documentation for this API indicates that a return value of 0 indicates an error and a return value of non-zero indicates no error. The System Semaphore Release checks for a zero return value and generates the error if it is found. This is backward. Also, I would find an error value of 1 more friendly than an error value of 0. At least this won't send you on wild goose chases.
(2,870 Views)
