reliable image grabbing?
I grab images in a while loop and a few times in a minute i get an weird image that is not sync-ed well. What's the best way to grab an image the most reliable way. Don't need a lot performance...
or how do i solve the sync problem. I use a 1409 and labview 6.2
(2,717 Views)
I had this same problem. I solved it by first initializing my IMAQ session (Grab Setup) outside of the loop, then getting (Acquire - from memory) the image in the loop, then closing the session after the loop. This should work for your case as well.
(2,717 Views)
