remaining work in close panel%3F event
I am complicated a little bit about close panel? event.
I want to clean some remained work in consumer rountine which connected by queue.
When I use the following code, the breakpoint cannot be checked in highlighted mode and didn't stored any information to a file.
Can you recommend how to realize the exit function when a user pressed the close panel button?
(2,893 Views)
Accepted by topic author labmaster
Always discard the event, and close the panel after the exit case gets processed.
George Zou
(2,886 Views)
