remote front panel,help?
I also faced the same problem long time before(firefox). after that i installed some activeX and it is working fine.
for more detail see this post-http://forums.ni.com/ni/board/message?board.id=170&message.id=400151#M400151
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 11 of 19
(2,123 Views)
We are not aware of any problems using remote panels in Firefox. I test with Firefox frequently.
marp84, unfortunately the error that you posted is a generic error and could be for a number of reasons.
As Ravens suggested:
1) Try to view the web page on the same computer that the VI is running on. This will prove it's not a network issue.
2) Try opening it in IE. This will prove it is not a browser installation issue.
3) Try a simpler VI to make sure it's not a problem with your VI.
If none of those make a difference then the problem is likely going to be with LabVIEW's installation or configuration and we can work from there.
Nathan
Message 12 of 19
(2,109 Views)
Where i can get that some activeX?
Message 13 of 19
(2,099 Views)
i've labview labview 8.5 too, when i try to make web publish it's works in server computer or localhost. but why when i try to make it at labview 8.6 it's doesn't works and it's says "fatal error during operations, closing connections".why it's happen?
Message 14 of 19
(2,078 Views)
What exactly does 'when i try to make it at labview 8.6' mean?
Please try to provide more than one or two sentences in describing the problem.
Message 15 of 19
(2,067 Views)
it's mean: i try to make web publish with labview 8.6 and view it at firefox the web publish can't view it.but with
labview 8.5 it's works.
can you tell me why?
Message 16 of 19
(2,058 Views)
Hi marp84,
Did you install the plug-in?
http://digital.ni.com/public.nsf/allkb/151BE12C055F57CE86257043006CB4B3?OpenDocument
Flash
Message 17 of 19
(2,042 Views)
i use labview 8.6,it's can use for it?
Message 18 of 19
(2,028 Views)
Yes you can.
Flash
Message 19 of 19
(2,002 Views)
