remote panels in 2010 service pack 1
Just installed service pack 1 for LV 2010 and NI-RIO 3.6.0
and this is the message I get in my browser when I try to open a remote panel on a cRIO
Any thoughts?
- James
Using LV 2012 on Windows 7 64 bit
Message 1 of 23
(4,543 Views)
Free lessons in speaking Greek?
Lynn
Message 2 of 23
(4,538 Views)
James,
   Which browser are you using? What language setting is it on?
Regards from Austin,
Ben J.
Message 3 of 23
(4,501 Views)
I am using Internet explorer 8
and I have tried firefox with IE Tab2 using the internet explorer's rendering engine
the language did not change from before I upgraded to LV2010 sp1  but the encoding is set to western european (windows) in firefox which was also the same before I upgraded
- James
Message 4 of 23
(4,467 Views)
James,
   Very interesting. Did this work previous to the upgrade?
Ben J.
Message 5 of 23
(4,447 Views)
Yes it worked before the upgrade.
I called in for support and was told to try and repair the installation and that did not work either
- James
Message 6 of 23
(4,424 Views)
I have the same problem. First: with LabVIEW 8.51 I had no problem with running remote panel with FireFox. Now I can run it ONLY on Internet Explorer. Second: I have the same corrupted fonts on Remote Panel, when I try control it with right mouse cklick
Message 7 of 23
(4,302 Views)
Hi Armen,
Please provide information on the following:
-What changes has occurred since it started messing up? Did you upgrade to 2010 SP1?
-Have you tried creating a new VI? Try that and see if it still sees the corruption
-Does the corruption only occur whenever you right click?  Or is the text on the front panel also corrupted?
Che T.
Message 8 of 23
(4,283 Views)
Hi Che,
Chronologically it looks so:
1. I had running execution, created by LV 8.51. Everythings just fine, I see and control my application with FFand IE without problem. All fonts are OK.
2.Upgraded to LV 2010. I have created new executable - running. On FF I see only all headers, created in Web Publishing tool, instead of my application - just a little quadrat. With IE everything OK, with right mous cklick I can gain a control, fonts are correct.
3.Upgraded to LV 2010SP1. Same behaviour plus corrupted fonts on IE.
Message 9 of 23
(4,276 Views)
I had a similar issue. The problem is that the upgrade deleted the following resource file:
C\Program Files\National Instruments\Shared\LabVIEW Run-Time\2010\English\lvapp.rsc
This is a known issue :
http://digital.ni.com/public.nsf/allkb/06B37C3CD0710E5F8625787F0012353E
http://zone.ni.com/devzone/cda/tut/p/id/11869 (CAR 202900)
Attached is the resource file from my installation.
Vinny
Message 10 of 23
(4,258 Views)
