remove annoying "tip strip" controls and structures
There are typically three types of tip strips: 1. over the terminals, 2. over the controls (user modifiable), 3. Labview system (case, sequency structures, etc). Please the example image.
Does any one know how to disable the Labview system tip strips? I don't need labview to constantly remind me of what the strucutres are. It's too annoying and the worst feature in LV. Your inputs will be greatly appreciated.
thanks
-Joe
p.s. I use LV 7.1 on XP Pro SR1
(3,282 Views)
Look in
Tools > Options > Miscellanious
Tip strip at top left corner.
see attached
(3,282 Views)
You're right... it doesn't make them dissappear..
:o(
(3,282 Views)
As pointed out in this posting from last month, that does not eliminate the tip strips over the LabVIEW structures - only those on the fron panel. Per Greg's advice in the posting, we need to make th
is a feature request to NI to eliminate them in a future version.
(3,282 Views)
where can we make a request?
(3,282 Views)
Thanks Dennis..
It's a good thing that you read all / most posts.
(sorry Joe)
(3,282 Views)
(3,282 Views)
