remove blank element in array
need help how to remove empty elements in an array?
Message 1 of 17
(27,000 Views)
Hi jeyanthi,
how do you mean it? If you want to remove them manually, right click on the element, select data operation and remove element. Or do you mean with a part of code?
Mike
Message 2 of 17
(26,997 Views)
 as a code? how can it b done?
Message 3 of 17
(26,992 Views)
Hi Jeyanthi,
See this link to not only remove all empty elements from an array, but also 'any' repeated element from an array. Smiley Happy
Wire an Empty String Constant to the Element to Remove variable in that VI & it ll do the job for you. Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
Message 4 of 17
(26,991 Views)
thk u it just simple only...
need another help
i get the data frm text file and pass it to array
let say my array is like this
abc
cde
abc
cde
ok let say i wana remove the cde from the text file to..how can it been done?
Message Edited by jeyanthi on 06-09-2008 01:42 AM
Message 5 of 17
(26,986 Views)
Hi jeyanthi,
i can´t find the original post, but here is another solution.
Mike
Message Edited by MikeS81 on 06-09-2008 09:03 AM
Message 6 of 17
(26,982 Views)
how to remove tht data only frm text file
Message 7 of 17
(26,978 Views)
Hi jeyanthi,
what do you mean? I thought you have an array of your data.
Mike
Message 8 of 17
(26,977 Views)
Message 9 of 17
(26,975 Views)
Hi jeyanthi,
if you want to delete somthing from a txt file, you have also first to read the data, remove the part you want and to write the new data into the file. So i think you can do it with the array version. For example something like this:
Mike
Message Edited by MikeS81 on 06-09-2008 09:32 AM
Message 10 of 17
(26,971 Views)
