remove line feed from a string
In the attached VI, I expected my output to be one long string, but instead it is a string with what looks like to be line feeds inserted. That is my output looks like:
    xx xx xx xx xx xx xx xx
and what I want is:
    xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
Is there an easy way to eliminate the linefeeds?
Thank you
(23,087 Views)
Accepted by topic author chuck72352
Just do a "Search and Replace String" with LF as search string, empty string (or probably a space if needed) as replace string, and replace all instances set to true.
Hope this helps
(23,083 Views)
A picture is worth thousand words.
(23,079 Views)
So then is a snippet worth a thousand thousand words?
Stephen Meserve
(23,049 Views)
So I ran into this exact issue yesterday where using a \n or a LF constant didnt work- saved a vi as an example to post up with, then I found this thread and saw that you have to use the EOL constant- the sad part is I apparently kudo'd one of these answers back in october Smiley Tongue
(22,509 Views)
I right click and change S&R to Regular Expression mode then I choose \v as the search string. This removes all forms of vertical whitespace, be it CR, LF or any combo thereof.
(22,504 Views)
