remove menu ring scroll bar
Does anyone know how to remove the scroll bar on the Menu Ring?
The Menu Ring is fine until you get more than 25 inputs and then it adds a scroll bar (see attached)
(2,695 Views)
I believe that can not be done.
What type of application requirement do you have that this behaviour is inconsistent with?
We may be able to offer suggestions if we knew more about your challenge.
Ben
(2,692 Views)
