remove units in cluster
I need to output data in cluster to a .dat file, however, the two elements in the cluster have units with them, which prevent me to do what I want to do. How can I remove the units, then I can do cluster to array and output the data?
(4,239 Views)
What do you mean by units? Can you post a screen shot
(4,216 Views)
Hi Chuyu,
there's a "convert unit" function in the numerics->conversion palette. Use this to remove the units (converting "1m" with a unit of "m" results in "1")...
(4,209 Views)
Thanks! Problem solved. I unbundle the cluster to get 1D arrays, then array to spreadsheet string, then write file
(4,193 Views)
