remove vi from lvlib
Please help me
I have created a lvlib ( just to try ,and i seriously regret )
So  i want to remove all the subvi in these lvlib, keep the same name of the SuB vi
And erase this devil LVLIB
Is there a manner to put out vi from a lvlib  and keep the  top level vi connected with theses sub vi
(4,580 Views)
Quick Search will sometimes make your life easier. Post back.
Mathan
(4,574 Views)
open the vi lib and choose remove from proj.
(4,566 Views)
but I have tried a lot of things
Remove one by one all the vi I can but for some VI  remove from project doesn' t exit
And when I remove my lvlib i retrieve it in my dependencies
(4,558 Views)
Do you still have your original VIs outside of the lvlib on your computer?
If yes, you can remove the lvlib from your project, and add the VIs directly in the project.
The link between the VIs and SubVIs will be done automatically when you open the project, or a VI.
Olivier L. | Certified LabVIEW Developer
(4,520 Views)
