remove zero's in a certain area
@ggqshqs wrote:
thanks for your answer ben, but could you explain it in another way because i don't really unerstand it very well
Not without doing the work for you and that would not do you any good LV-wise.
If you don't follow my appraoch then you should develop your own.
Sit down and start "doing the work" by hand with some scratch paper to take notes on any intermidate stuff you need to remember and write down exactly what you are doing so that you have a manual procedure you can hand to a buddy. If the procedure is correct your buddy should be able repeat the steps you outline.
After you have a method outlined that should work manually, THEN turn to converting it into code.
Ben
Message 21 of 25
(818 Views)
Sorry guys, The problem seemed rather interesting so I coded it up.  Altenbach's tip on array max-replace was a nice pointer NaN's self inequality proved interesting too.
 Yes, I know a FBN would be more elelgant than both SRs.
Message 22 of 25
(809 Views)
If all of the values are either zero or one why is your data array DBL .... wait! that was supposed to be Christian's line.
Sorry.
Ben
Message 23 of 25
(805 Views)
Sorry.
Ben
so you can do the self equality check rather than summing the 3x3 array
And there I go begging fr a RG nomination
Message 24 of 25
(803 Views)
Of course there are some shapes this doesn't quite work with.  X's H's.
Try this instead
Message 25 of 25
(785 Views)
