removing delimiters
A TCP read returns a number and a delimiter, cr/lf.  No matter what I tried, the only way I could get rid of the delimiter was to convert the string to a number and then back to a string.  Shouldn't there be a simplier way?
Message 1 of 14
(6,010 Views)
Search and Replace under string functions.  search for end of line constant and replace with empty string constant
Message Edited by JeffOverton on 03-07-2008 12:06 PM
Message 2 of 14
(6,009 Views)
The EOL constant will be platform dependent. A more precise solution is to wire in the explicit string you're looking for.
Message Edited by smercurio_fc on 03-07-2008 11:11 AM
Message 3 of 14
(6,002 Views)
Didn't work.
Thanks anyway.
Message 4 of 14
(5,998 Views)
What do you mean it didn't work? What exactly didn't work? What is the string that you're feeding in?
Message 5 of 14
(5,992 Views)
If it still does not work, please create an indicator on your string, run the VI so the indicator contains typical data. Now change the indicator to a constant ("right-click...change to constant") and copy it to a new VI together with only the code you are using to remove the delimiters. Save it and attach it. 🙂
Message Edited by altenbach on 03-07-2008 09:22 AM
Message 6 of 14
(5,991 Views)
I wasn't referring to your post when I said it didn't work but I think I tried your idea.
The TCP/IP Read returns a number string that when concatenated with another string shows that the first string is terminated by a cr/lf. All the methods I tried except converting the string to a number and back to the string did not result in a string that when concatenated did not have a cr/lf.
I made a simple vi where I added a cr/lf to a string and could remove it but it didn't work with the string from the TCP/IP.
Message 7 of 14
(5,972 Views)
Then it may not be a CRLF. It may be CRCR or LLLL. Please follow altenbach's instructions, as it will be much easier to see what's going on. There is no reason for you to convert the string to a number and then back to a string again. This is a candidate for Rube Goldberg code, and I don't think you want to be another entry in that Hall of "Fame".
Message 8 of 14
(5,966 Views)
I'm not sure I understand altenbach's instructions. There must be a way to parse the string that tells what the delimiters are.
RE: Hall of Fame. I take my entries into the Hall of Fame as badges of honor. If I can make something work, then I win; that's why they pay me the big bucks. 🙂
Message 9 of 14
(5,962 Views)
have you tried? At which step did you get stuck?
A string is just a string, delimiters could be anything you define as such. 😉
Try to display the string in a string indicator set to "\-codes" or hex display since you might be dealing with stuff that is not displayable in normal mode. 😉
Message 10 of 14
(5,951 Views)
