renaming visa resource names
Folks, for some strange reason my visa resource names were changed.  I suspect that I had TEKVISA loaded on start-up and it somehow changed my resource names by accident.  Regardless, I attempted to fix them using the MAX utility, but it does absolutely nothing.  I even tried resetting my resources which really screwed things up.  So now when I try to select a previously named resource for my VISA command, it is not there.  What is the name of the file that Labview 8.0 uses? where is it located? Last, how can I fix this and prevent it from happening again?
Thanks in advance,
Rick
(2,441 Views)
- Partha ( CLD until Oct 2027 🙂 )
(2,427 Views)
