reorder table
Hi, I need to re-order Table 1, in such way that it becomes in transformed in Table 2.  Afterwards I Table 2 to be stored in an excel file:
Table 1
1,0          212
1,1          34
1,2          3
1,3          4
1,4          3
1,5          324
1,6          234
1,7          325
1,8          532
1,9          42
2,0          423
2,1          4
2,2          324
2,3          32
2,4          34
2,5          234
2,6          324
2,7          23
2,8          4
2,9          35
3,0          5
3,1          426
3,2          546
3,3          54
3,4          2
3,5          34
3,6          324
3,7          234
3,8          234
3,9          234
4,0          234
Table 2
                0,0          0,1          0,2          0,3          0,4          0,5          0,6          0,7          0,8          0,9
1,0           212         34           3             4             3             324         234         325         532         42
2,0           423         4             324         32           34           234         324         23           4             35
3,0           5             426         546         54           2             34           324         234         234         234
4,0           234
In Table 2 it can be seen that in the first row are the decimal part of the values that appear in the first column of Table 1. On the other hand, the first column of Table 2 is composed of the integer part of the values that appear in the first column of Table 1
Thnak you very much.
(3,763 Views)
Your description seems incomplete.
  1. Does it always start with 1.0 or could it be something else. Could values in the first column be negative?
  2. Are the values always consecutive and incrementing by 0.1 or could there be gaps.
  3. Is the first column always sorted?
  4. Could there be an unlimited number of rows?
Here's a simple example snipped that assumes an unlimited number of rows starting with 1.0 and does not assume that the first column is sorted.
There are many ways to do this. I assume you know how to write the final array to your desired file format.
(3,757 Views)
  1. Does it always start with 1.0 or could it be something else. Could values in the first column be negative?: It always starts with 0
  2. Are the values always consecutive and incrementing by 0.1 or could there be gaps. Always consecutive and incrementing by 0.1
  3. Is the first column always sorted? Yes.
  4. Could there be an unlimited number of rows? No.
(3,754 Views)
...And the input is a nx1 array.
(3,753 Views)
Well, your example data starts with 1.0, already breaking the rule. 😄
Your specification change is nothing a "+1" here or there cannot fix... 😉
(3,751 Views)
