repeat operation on condition
hi,im new here..
i have a question..how can i repeat an operation if the condition or comparison is not true...
if the condition is true, then procede to next operation.
thanks
(4,323 Views)
Use a while loop.
(4,317 Views)
the task is to randomly simulate a number greater than 80,if the number less than 80, it will continuously simulated a number. if the number is greater than 80,
it will stop the loop,add with another number and display the result.. the problem here is how can i obtain a true output inside the loop
(4,302 Views)
(4,296 Views)
Try using the "Greater Than" function found in the Comparison palette, instead of the Express VI you're using now.
(4,292 Views)
This VI just points out how dynamic data can be totally misused and misunderstood. The result of the comparison would be a true/false and it is correctly stopping the loop but the output is also being used to represent a number. Just plain wrong. If you had used the normal comparison function, as mentioned, all of this would have been clear.
(4,287 Views)
thank you all..i manage to solve it 😃
(4,278 Views)
