replace numbers in cols while opening more than 1 file
Huhu...
I need some help, please...
in the first part of the VI i read more files...then in the FOR-L i replace all the zeroes in the 5th col with values of the row before....but this doesn´t work, if the 2nd file already starts with 0...so at this point the prog should take the last non zero value from file before....
if i have.... 247,5....248,3....NEW FILE STARTS....0,00...0,00....273,2....274...0,00...0,00
it should be: 247,5....248,3...248,3..248,3..273,2....274....274....274 .....
I tried to solve that with a local variable, but does not work correctly.
what´s wrong with the non cool local variable? What must i change?
Here is the VI and the example with local variable how i tried....
Greetings
(2,625 Views)
Duplicate post, please go here
"Everything should be made as simple as possible but no simpler"
(2,619 Views)
something went wrong....
here is the other thread
*don´t know*
http://forums.ni.com/ni/board/message?board.id=170&thread.id=496679
(2,607 Views)
