replacing Strings (again)
Hallo,
I have a string with lots of numbers in scientific notation, e.g. 1,23456E+10 (German OS). I want to save it to a spreadsheat file, but before that I want to replace all "," with "." and all "E" with "e". (Otherwise GNUplot cannot read them).
With my idea and the ideas of the LabVIEW-Forum, only the first ones were replaced.
Example: 1,0E-6 1,0E-6 becomes 1.0e-6 1,0E-6 and NOT 1.0e-6 1.0e-6
How can I manage that? The common "Search and Replace String" works but stops after the first match.
Arno
PS: Please send VI's that can be loaded with LabVIEW 6.1^.
Arno
Please help me, thank you !!
Arno
PS: I am using LabVIEW 6.1."
(2,945 Views)
Already answered here.
(2,945 Views)
Hi Arno
I am attaching a vi which converts the string in the shape u desire.
Hope it works for u. Your feedbacks are welcome.
Best Regards,
Nirmal Sharma
(2,945 Views)
The E-->e is easy, just use "to lower case". 🙂
To replace all using search and replace, just wire a TRUE to the "replace all?" terminal.
The attached example in LV6.1 shows both methods.
(2,945 Views)
