replay graph in a video
Hello experts need help,
I have a 10 second video and a graph (array of values) taken at the same time in an experiment for same duration,
Ex: the object in the video is a moving part at 1hz, at every second the moving part touches some electrode and gives out voltage which is acquired by a daq and saved as array into excel (time vs voltage),
how do i replay that 10 second graph overlaid on the original video, so that finally i have a single video (wmv or any video format) that has the graph running along with the moving part for presentation purpose (so that visually it will be easy to see the voltage graph synced up with the moving part)
Thanks in advance
(3,244 Views)
Can any body give me some idea please ??
(3,221 Views)
Hi freemason,
I'm looking into a VI right now to see what can be done.  I would assume you are using the Vision Acquistion Software (IMAQ)?  Have you looked at using the AVI palette (Vision and Motion»Vision Utilities»Files»AVI)?
(3,200 Views)
