report generation in labview 8 without the toolkit
HI
I have a typical problem. I want to generate report in MS word format. Unfortunately I don't have the toolkit. I am wandering whether there is a method to generate report without using the toolkit or I have to get the toolkit to be able generate report.
Shreeharsh
(3,027 Views)
Yes you can,
you can do the same as NI has done and built it from scratch with ActiveX. But I advice you to get the NI toolkit, it works with a lot of Office releases and does (almost) anything you want!
Ton
My LabVIEW Ideas
(3,015 Views)
How complex are the reports that you want to generate?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,995 Views)
Hi mikeporter
I have attached a dummy report. The report will be exactly in the same format in *.doc file. I will appreciate if you can help me out.
Shreeharsh
(2,990 Views)
Hi Shreeharsh,
As Ton was saying, making this report will be a lot quicker and easier using the Report Generation Toolkit.  If you still want to pursue using ActiveX, a great place to start is the Using ActiveX with LabVIEW help file.
Michael
Applications Engineering
(2,936 Views)
