report generation in windows
The report VIs generate either a "Standard Report" or "HTML Report". There is also a "Text Report Example" VI in the shipping examples that generates a text-based report. If the report VIs don't generate the kind of report you want then you will need to create your own. If all you want is a table of data then the Write to Spreadsheet File VI may be sufficient for you.
Message 11 of 11
(498 Views)
