report generation set font vi messed up
Hello all,
I am not sure if I am the only one who has had this problem.  I just upgraded to the developer suite professional editon.  I installed the software and then installed the Report Generation Toolkit.  None of my VI's I had written that used the Report Generation Toolkit would execute.  It affected these VI's, at least these are the two I have found, Excel Easy Text and Excel Easy Title.  The Set Report Font.vi  had all the input terminals connected to the wrong type.  I was able to reconnect the inputs to the correct type, but it just has me a little confused.  Has anyone else seen this or do I have a botched version of Report Generation Toolkit?
Ben Babb
(3,194 Views)
I have not heard of this, but if you encounter further problems please repost.  Also, it will be interesting to see if anyone else has seen this problem!
Thank you,
Best Regards,
JLS
Best,
JLS
Sixclear
(3,184 Views)
Yes, Yes, Yes. Same exact problem. I had 6.0 base pkg. Then upgraded to the prof develop. pckage and have been "chasing" report generation vi's ever since. Now I upgraded to 8.0 and none of them will work. A lot of "polymorphic" and "bundle by name" errors. I don't even know where to start. Jim
(3,149 Views)
My problem came from having different llb's that had the older version VI's used for report generation.  I had to go through all my libraries and unpackage them.  Then delete all the older version VI's.  Once I did this I reinstalled report generation toolkit and all is well.  It took some time, there were a lot of code over the years.
Ben.
(3,145 Views)
I look into mine. This is my one beef with Labview, as powerfull as it is, it sure is a nightmare with upgrades Jim
(3,140 Views)
