report generation toolkit 2011 problem report office
error message: Property Node (arg 1) in NI_Word.lvclass:Word Set Paper Size.vi->
Message 11 of 16
(1,400 Views)
Seeing an error message without seeing any code is an exercise in futility!  If you are using LabVIEW 2011 and have the Report Generation Toolkit available, and if you are using it correctly (do the wires that connect the Report Generation functions on the upper corners look like little green chains?  If so, that's good), then you shouldn't have too many difficulties unless you are doing something "strange" (and without seeing the code, it's not even a guess what this could be).
Attach a VI, include a Zip file, add a Snippet, but don't keep asking for help without giving us sufficient information to provide help.
BS
Message 12 of 16
(1,391 Views)
I belive the problem is in office 2013. Programm tested in different pc ,win 7 and office 2013, file bildid and saved witch errors in tables.
The same programm executed well in pc with office 2010
Tnx to all 🙂
Message 13 of 16
(1,364 Views)
No still long way to go? Please talk to NI guys and check that is there any issue with 2013 compatibility?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 14 of 16
(1,350 Views)
Hello
Here is a readme for Report Generation Toolkit 2011 .
http://digital.ni.com/public.nsf/allkb/91D039D237901D54862578E0005C49C0
As you can see Report Generation Toolkit 2011 supports Microsoft Office 2010/2007/2003/XP.
Message 15 of 16
(1,342 Views)
This explains everything. Hope your problem solved
--Ranjeet
Message 16 of 16
(1,339 Views)
