report generation
Hello ,
Ihave a report generation VI which is using all Excel VI's..... while building an application do i need to add any excel.llb in support files, or else normal application building is sufficient?
(3,656 Views)
HI,
Yes, you need to add the "_Excel Dynamic VIs.vi" in always included while building the application.
Hope this helps
Regards
Santosh
(3,640 Views)
can u pls elaborate on this....wanted to knw in detail wat all libraries to be added...
C:\Prorgram Files\National Instruments\LabVIEW 8.0\vi.lib\addons\_office.............this link has all office libraries in my system, if u could let me knw in specific it wud be of gr8 help.
thanks.
(3,635 Views)
Can you please compose professional messages using real English words and not resort to "text" speak when typing replies on the forums?
(3,629 Views)
HI,
If you are using excel report generation VI's then add the C:\Prorgram Files\National Instruments\LabVIEW 8.0\vi.lib\addons\_office\_exclsub.llb\_Excel Dynamic VIs.vi in always included while building the application.
This VI will add all necessary vis in the application.
Regards
Santosh
(3,624 Views)
