report ms word template
hello LV universe
hai i have a problem , i want to make a measurement report , i want you to give me advice , how i made a report that contain input data in a text (ex laboratorium name) and data that i get from collecting data
you can see it in picture attachment below ,
i just learnig about report generation to , but i cant find how to , make input data beside the question text
  thanks
(2,617 Views)
You need to add bookmarks to your template where you want the data to be inserted.  And then in LabVIEW, using the "Append Report Text" VI, add the text at the bookmark using the MS Office Parameters input.
aputman
(2,590 Views)
thank you for the advice @aputman
what do you mean with the template is the same as the image that I attached below , sorry i dont understand with adding bookmark to my template.
do you have refrence for me
(2,531 Views)
The Word template (the actual document) not the path to the template.  Insert -> Bookmark and give it a name.  In your LabVIEW code, reference the bookmark name in the MS Office Parameters input. When you execute this code, the mouse cursor will be moved to the bookmark location before the text is inserted.
aputman
(2,510 Views)
I get it sir ,
i curious i can find bookmark menu in ms word , but i cant find bookmark menu in ms excell , so how can i use ms excell as a template for my result
(2,460 Views)
