reset boolean
We have made a simulated alarm system in LabVIEW. Now we've made a numeric keypad to activate the alarm. This keypad sends out a boolean if the code is right. But we want to de-activate the system too. Once we activate the system it keeps going on and on and......it never stops.
So we need to reset the line between our keypad and alarm system to stop our alarm system. But the alarm should be stopped with the same code as we turned it on with. We put the keypad in a while loop that stops when the code is entered. So the keys are not responding after turning the alarm on. I submitted a .jpg of the project. The boolean-indicator on the right shows the activity of the system. Does anybody have a tip for us how to solve this (little) problem ?
(3,272 Views)
Problem solved ?
If not mail me the VI (see Google) then we can continue in Dutch
(3,221 Views)
I do not know if you already have the answer.
But you must place a while loop around the code. With the while loop you are capable of entering a new code to shut down the alarm.
Good Luck,
John
N Netherlands
John
NI Netherlands
(3,187 Views)
