reset iteration counter at the end of execution
I'm using the iteration counter inside a while loop to measure the time of a process. If I end the execution of the program and run it again, the iteration counter does not reset to 0. How can I make it automatically reset at the end (or beginning) of the execution?
(3,682 Views)
Try posting your code as a snippet.
(3,680 Views)
Here is the code with subVIs included. another subVI will be in the next post as I can't upload more than three files at once.
(3,677 Views)
the last subVI
(3,676 Views)
Alex Thomas, University of Manchester School of EEE LabVIEW Ambassador (CLAD)
(3,671 Views)
Accepted by topic author shears
You have to wire the initialize terminal with zero.
(3,665 Views)
Thanks both for help, I understand the process now.
(3,654 Views)
