reset numeric control to default
Just wondering if you can reinitialise a numeric control to default value while a vi is running. I want to enter a batch number, when I press end batch button I want the batch number numeric control to return to either zero or blank.
David
(4,808 Views)
Accepted by topic author dvdmoylan
Yes you can, see attached example.
BR
/Thomas
(4,802 Views)
Thank you Thomas,
Your build was different to what i required but your method of using the refrence to activate the invoke node has set me on the right track.
Thank you
David
(4,778 Views)
