reset scale layout while running
Hi there,
Does anyone know how to reset the scale layout of a waveform graph while the vi is running. I want to do this because for some reason sometimes the cero gets out of the limits of the draw
greetings
CJMV, Chile
(3,760 Views)
use the "Scale Fit" property node for the scale you want to reset.
0 - no auto scale
1 - auto scale once
2 - auto scale
-Joe
(3,750 Views)
I'm afraid crimolvic problem is not related to autoscale...
"Reset scale layout" can't be accessed programmatically. So you can't correct a corrupted X scale ! 😞
However, you can protect the scale from being damaged by unchecking the autoadjust scale property (right click > advanced). This will keep the graph size unchanged when the Y scale is modified.
Have a look at this thread
Chilly Charly    (aka CC)
(3,743 Views)
Thank you,
I will try what you said.
Unfortunately the thread that you attached is not available.
greetings,
CJMV - Chile
(3,735 Views)
