reset table
I have  attached vi for resetting the table , its working but the older values appears after the table is reset,
any solutions for it would be appreciated
(3,427 Views)
If you use shift register don't forget to put in your register your value from the case.
see the attachments , it should work.
Regards
Greg S.
CNRS
LV 7.1 8.2 8.6 2009 2011 2012 2013 2014
LPMC - CNRS
N'oubliez pas de complimenter cela fait toujours plaisir.
(3,423 Views)
Why wouldn't you just wire a constant to the wire instead of using a local variable? Have a look at the attached image. Also, I would recommend that you look into using event structures.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,420 Views)
shrekt: Is the uninitialized shift register intentional? Do you know the behavior that will occur?
(3,396 Views)
