reset the ports before running the program
I found out an interesting thing. My machine goes sleep after a while. When I wake up the machine, and run the VI to measure temperature(my first program :]), the program does not recognize the DAQ device. I am using LabView 7 and Ni-DAQ 7.2. I think when I wake up the machine, the port from the DAQ pad to the computer is not ready to function somehow.
But if you have a similar problem, or know what to do to fix this error so that I do not need to force quit or restart the machine, please let me know.
(2,384 Views)
Hello mikeee,
Thank you for contacting National Instruments. Sleep/suspend mode is known to cause problems with PCI and PCMCIA DAQ devices for both Windows and MacOS. Take a look at the following page located on our website:
My PCI Board or PCMCIA Card Does Not Respond after My Computer Recovers from Suspend or Sleep Mode
It is suggested that you disable sleep/suspend mode for your system to prevent this problem. If you have any further questions on this issue, let me know.
Scott R.
Applications Engineer,
Scott Romine
Course Development Engineer
(2,384 Views)
