reset to initial values after program ends
How can I reset all my values to their default after the program has finished executing?
(3,099 Views)
Hi teky,
I would use some sort of case structure (that will determine whether or not your program is finished running) with the Invoke nodes of the things you want reinitalized to their default values (i.e. an array with default values, or a rocker button, etc).
Hope this helps
Anthony Wong
University of Toronto
Chemistry Department
(3,094 Views)
Also, you can create an invoke for the vi itself and choose "Reinitialize All to Default". Place an unwired invoke node on the diagram from the application control palette then right click on it to change it from the application class to vi class.
(3,085 Views)
