resetting array data to empty
what i have is a 2 d array to 1 d array conversion.  my problem is that i need to reset the output array to empty before each time i run it.  right now it keeps adding the data for each run.  any advice?
(3,127 Views)
I think you have to connect an empty array constant to the shift register.
BR,
ThSa
Message Edited by ThSa on 08-23-2006 10:27 PM
(3,123 Views)
wire an empty array constant to the input of the shift register.
regards
Ray Farmer
Regards
Ray Farmer
(3,114 Views)
thanks to both of you.  i was originally trying to initialize an empty array after the data came out of the for loop.  thank you
(3,110 Views)
