resetting counter
I am using the attached vi to perform buffered photon counting using my PCI-6602 card.  The problem is that the counter continues to increment during each iteration of the while loop.  I want the counter to restart from 0 after acquiring the array of 256 elements.  How would I go about modifying the vi to perform this task?
Anthony
(4,128 Views)
the vi is in Lv 8... attach it VI again after converting into 7 version,,, so can get better idea,,,
regards
manisha
(4,119 Views)
hi, not able to view LV8 code... but is this what you wanna do?
attached (LV7)
regards,
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(4,112 Views)
nice code ian fung,,, but put some time delay in while loop so the increment in count can be observe....
attaching one more,,  idea,,
manisha
(4,108 Views)
Sorry, I only have LV8.  I have taken a screenshot of my block diagram so you can see what's going on.  This vi was a modification of the example vi "Count Digital Events-Buffered-Continuous-Ext Clk.vi".   Very interesting vis you have posted, butI don't think they are what I'm looking for.
-Anthony
Message Edited by AntLee29 on 05-26-2006 03:11 AM
Message Edited by AntLee29 on 05-26-2006 03:12 AM
(4,107 Views)
hi,
I noticed that, and purposely removed it to realise that actual execution time.
If the final count & no. of count are of interest, even 1ms matters 🙂 if this is to be for production test sw.
Thanks & Cheers!
Ian F
依恩与LabVIEW
(4,097 Views)
