reshape array in labview from matlab coding
I have following matlab code and I want to do it without using LabView MathScript. I want to do it using labview reshape array function. Can any body guide me how to do it.
Reshape a 3-by-4 matrix into a 2-by-6 matrix in MATLAB
A =
    1    4    7    10
    2    5    8    11
    3    6    9    12
B = reshape(A,2,6)
B =
    1    3    5    7    9   11
    2    4    6    8   10   12
So how can do this in LabView using reshape array function. See attached image below for details.
The result is not as same as matlab. Can any body guide me how can i get same result as matlab.
JK
(4,601 Views)
Accepted by topic author josephkirmani
Hi Joseph,
atleast a quick&dirty two-step process:
(Using an older LV version I cannot use the concatenating output tunnel.)
Altenbach may simplify this. 😄
(4,596 Views)
Also If I have 1-D input array then what change do I ned to make in it?
(4,578 Views)
Hi Joseph,
in my snippet you see that "array1" indicator. This will be your 1D array input when you want such an input - if it has the same/similar content as array1…
(4,568 Views)
