resize a multicolumn listbox
Hello!
I want to resize a multicolumn listbox. But i don't want to resize wiring the number the columns and rows by his property node. I want to wire automaticlly the width and the height exactly of the multicolumn listbox. I'm looking forward the property node but i haven't found it. How can i wire this values, thanks.
Larson
(5,270 Views)
There is no property node to change the size of a list box.
However, there is a workaround : you can set the cell sizes and the number of rows and columns.
Accordingly a solution is to save the initial cell dimensions, create a big single cell listbox with appropriate dimensions, then reset the cell sizes.
The attached vi does the trick, but I left some work for you : you'll have to modify it to also adjust the Listbox height 😉
Chilly Charly    (aka CC)
(5,251 Views)
Hi Larson,
Here is an example that will resize all the cells inside a multicolumn list box,
Enter the cell height and cell width and click on resize button
Hope this helps
Regards
Dev
(5,248 Views)
Hi!
Can you post the vi in labview version 7.0?
Thank you!!
(5,244 Views)
Here in LabVIEW 7.0
regards
(5,237 Views)
