resizing an image to a graph
Hello
I'm reading a jpeg image, converting it to an unflatten pixmap and plotting it to an intensity graph. Is there a way to resize the image to size of the intensity graph? I have seen similar options of resizing to a container on the front panel by using the 'zoom factor' in property node. Wondering if there is an easier way to do the same for intensity graph?
(2,167 Views)
Hi Robin,
You are talking about the 2DPictureIndicator: it supports a Zoom factor.
When you use the front/middle/background images in graphs you need to apply the scaling using your own routines…
(2,161 Views)
