resizing front panel with line decorations changes angle of lines.
Resizing a front panel with horizontal and vertical straight line decorations causes the lines to slant.
They cannot be made straight by resizing back. Is there a fix for this problem/bug?
(2,453 Views)
This is an issue with LabVIEW 7 when you have "Scale all objects on panel with window size" checked under VI Properties. The problem did not exist in 6.1.
The issue has been reported to NI R&D and they are working on a solution.
Zvezdana S.
(2,453 Views)
