resizing the height of a increment\decrement button
Is it possible to adjust the height and width of a numeric increment\decrement button without changing the text size?  I'm trying to use one with a touch screen and the small size makes it very difficult to operate though the touch screen.
Dale G.
(3,224 Views)
Sure. Right click on the control and select Advanced>Customize. In the window that pops-up, click on the little 'wrench' that is on the toolbar. This will change to a pair of tweezers. You can then select each of the buttons for the increment/decrement and drab them to any size you want. If you want to save this as a custom control, do a File>Save. Otherwise, just close the window and when asked to replace the original, say yes or do a File>Apply Changes.
(3,217 Views)
Sure, just go into the control editor (right-click...advanced...customize) and change the size of the trimmings.
(Of course this will not work with controls from the system palette)
Message Edited by altenbach on 11-16-2007 02:32 PM
(3,214 Views)
Thanks for the help.
Dale G.
(3,207 Views)
